Posted: Wed Mar 23, 2022 9:41 pm
Well, it's been a while. After losing both parents last year, my brother and I have had the unenviable task of clearing out Mum & Dad's house. They had a LOT of stuff. I only have a small 2-bed bungalow, and there simply isn't the space inside for most stuff, so it's been living in the garage. This has meant that the project has sat there gathering dust for the past 6 months whilst my priorities have been elsewhere. Dad was a keen and talented photographer, so I have boxes upon boxes of slides and negatives I need to deal with. I am starting to win though, and have ordered myself a large wooden trunk to store some stuff in, which will live in the garage, hopefully out of the way.
I had a bit of a clean up in the garage, and remembered that I was doing things with the headlining which involved the mirror and the interior light. This was a Fiat 126 item, and I don't like the design at all. I will be using either a stick-on mirror on the windscreen or one to mount AC Cobra-style to the top of the dashboard. Which I have yet to re-make as the original was garbage and the first one I made I wasn't happy with. I have ideas on what to do to make a better version.
However, back to the headlining: I had filled in the area with resin where the old mirror/light had sat and had bought myself a natty little interior light from Car Builder Solutions - you can switch it on inside the car by simply tilting the light lens. I like it for its simplicity, It was also the perfect size for the area where the original sat. So I cracked out the Dremel and after tracing round the lamp where it needed to sit I crudely hacked a hole in the headlining. Some file work followed (it still looks a bit crude but it is covered by the light body), and it's easy to press the light into the hole - it's held in place by a couple of spring clips.
More updates will follow as I continue my quest to make the garage a usable place again.
Nice lamp
Traced where it needs to sit
A hole (looks worse than it actually is
And finally there it is in place
Nice lamp
