Midas Weight
Posted: Thu Jan 06, 2011 9:36 pm
by graemedench
Thought this maybe of some interset got round to weighing my Mk1 Midas Bronze today. Has a 1275A (not A+) engine, small Bosch battery, pretty standard car, Original dash etc
Note lots of junk in the back probably around 30-40Kg + spare steel wheel and a full fuel tank.
Interesting about the weight distro at the front though. Might move the battery over to the passengers side and get a lightened flywheel to balance a bit better,
Any thoughts?
Re: Midas Weight
Posted: Thu Jan 06, 2011 9:52 pm
So 768 kg, I've seen the mk2 listed as 620 kg in magazines like CCC, so a masssive difference.
You should be able to adjust the corner weights for near-perfect distribution if you have ride-height adjustment on all four corners.
Still shocked at the weight, that's mk3 weight
Re: Midas Weight
Posted: Fri Jan 07, 2011 12:33 am
I checked a Bronze on Dutch plates. These cars are not known in the Dutch database so have to be weighted by the Dutch DVLA . According their system it is:
empty weight: 660 kg
drive ready weight: 760 kg.
So seems to be correct.
To compare with the data of my Convertible (also weighted):
empty weight: 730 kg
drive ready weight: 830 kg.
Re: Midas Weight
Posted: Fri Jan 07, 2011 12:53 am
by graemedench
I'll try remember and check my Mk2 Bronze. Not on the road yet but all the bits are stuffed in the back lol.
I thought those titanium Carb manifold studs I fitted today were gonna help lol, I guess I'll need to get more titanium.
Re: Midas Weight
Posted: Fri Jan 07, 2011 8:42 am
Inflating your tyres with helium could help as well.
