Micra engine in a Metro subframe
Posted: Sat May 14, 2011 7:26 pm
Looks interesting :o
Re: Micra engine in a Metro subframe
Posted: Sat May 14, 2011 8:46 pm
good luck :)
Posted: Sat May 14, 2011 8:48 pm
manifold wrote:good luck :)
Thanks, I'll need it, it looks like it will be possible to squeeze it in under the bonnet, just 8-)
Posted: Sun May 15, 2011 6:01 pm
by DavidL
So how much power/torque can you get out of one of those? How tunable(tuneable?) are they?
Posted: Sun May 15, 2011 6:10 pm
I'll be more than happy with more or less stock power to be honest.
Here's a very good read on some mods, that forum always runs really slowly with me for some reason
http://www.micra.org.uk/threads/40439-q ... by-EBBdude.
Posted: Sun May 15, 2011 6:43 pm
by DavidL
Stuart wrote:I'll be more than happy with more or less stock power to be honest.
Thanks Stuart. Looks like the slow running isn't just you!
Posted: Sun May 15, 2011 9:47 pm
by Jon Auty
Ive managed to get a honda b20 in the front of a standard length round nosed mini van so im sure you'll make it fit! Looks alot smaller lump
Posted: Sun May 15, 2011 9:51 pm
Yes it's much smaller, the problem on the Midas is the sloping bonnet and the headlights that are set so far back, even David with his special A-series engines needs a higher bonnet.
Posted: Sun May 15, 2011 11:19 pm
Stuart wrote:Yes it's much smaller, the problem on the Midas is the sloping bonnet and the headlights that are set so far back, even David with his special A-series engines needs a higher bonnet.
I recall the chap in the Caribbean fitted a Nissan engine in a Bronze without any problems. Pics on the Yahoo forum.
Posted: Mon May 16, 2011 9:42 am
Indeed, even has air-con by the look of it. That is an earlier and much smaller engine, with a much more compact gearbox that meant it could be pushed well over to the nearside.
Still it shows what can be squeezed into a MK 1 and MK 2
