Found a box of Bronze bits
Posted: Fri Sep 16, 2011 6:42 pm
Stuff keeps turning up. I have a load of original sales literature for bronze and gold plus unused bronze build manual which I will sort out and post. In the meantime I uncovered a box in the shed marked 'Bronze bits' leftover from breaking a 1986. It contains:-
Horn -Lucas25H
Front indicator/ sidelight units -R & L pair
Rear fog lights, 3 off, one new
Rear window cast hinge, drivers side
Bonnet pivot pins
Choke cable assy
Bonnet latch assy, both parts
Top engine tie bar mounting bracket
Rear window strut mounting brackets
Wiper motor only, SEV unit
Heater Motor,Lucas
Gearbox remote casting rear rubber mounting
Handbrake handle grip
Radiator mounting bracket set
Interior light door switches
Washer jets
Flasher units, 2 different types
Assorted small qty of imperial nuts and bolts
Anyone interested. Would prefer all went in one go, collected from SE Staffordshire. But is only an A4 size box so could post.
Horn -Lucas25H
Bonnet pivot pins
Choke cable assy
Heater Motor,Lucas
Washer jets
