A Series Iskanderian (Isky) valve springs and alloy caps
Posted: Tue Nov 15, 2011 11:09 pm
This forum is for Midas and Midtec Bronze enthusiasts. The Midas is a British car designed as a replacement for the Mini Marcos.
https://midasownersclub.co.uk/newforum/
If you have had a bit of work done on your car (camshaft, carb etc) and the valves are starting to bounce then you need to fit stronger valve springs and these look just the boys for you, but I suspect that fitting them on a stock engine would probably sap a bit of power because the buggers will take a bit more squeezing than the valve springs that you've already got.b1zbaz wrote:what do they do are they performance enhancing
