tailgate adjustment
Posted: Tue Sep 06, 2016 10:47 am
by chad123
Hi all,
is there any adjustment on the tailgate glass,as mines catching on the bodywork
cheers
Re: tailgate adjustment
Posted: Tue Sep 06, 2016 11:55 am
by fozzza
Im afraid not. I had the same issue with my mk 2. Its the gas strut that pushes the screen over. I ended up carefully removing the screen and fitted some offset rubber bushes in the screen and re sealed the hinges back on. It hasn't moved as yet.
Posted: Tue Sep 06, 2016 1:00 pm
If there are no bushes around the glass to hinge pins then the glass can slide down quite a long way. Fozzza's come up with an easy solution.
Be careful with the glass and struts, a few people have managed to break the screen.
Posted: Tue Sep 06, 2016 2:35 pm
by chad123
Cheers guys,i will have a tinker with it VERY CAREFULLY
JUST FOUND OUT COMPLETE KITCAR WANT TO DO A LITTLE FEATURE ON IT
Posted: Tue Sep 13, 2016 11:08 am
by chad123
Very carefully undone the strutt fittings and turned the bushes slightly, and now the glass fits properly onto the rubber
