So I now am the owner of a domino pimlico I bought it of my dad!
It's a 1966 988cc donor
Was built in 1987 and the current spec is;
998cc bored to 1014cc
Flat topped pistons
12g295 head
Rim flow valves
Fast road cam
Solid rockers
Duplex timing chain
Lightened flywheel
It has a piper x magnum 2780r cam
Vs4 valve springs
Cooper s valve retainers
Gas flowed head
32mm inlet
27mm exhaust
Had a 60 thou skim
And has a 10.26.1 compression ratio
And a AIF6 44 carb with bdl needle and red spring
Pick up this Saturday
Will post more update soon
Kerb weight is only 542kg so lighter than the mini also
Edited by Richard1384, 29 July 2013 - 01:45 PM.
