Currently I have a Mk1 Metro Radiator:
Which can be had for £98.29+VAT!
Wondering if anyone has any of these laying around? I am going to give Alistair a call tomorrow and see if he has any stock too.
Failing that, Would it be wise to upgrade to a later Metro radiator:
Available for £30 free delivery on ebay.
Will this provide better cooling than the Mk1 due to the nature of the inlet /outlet (cross flow?).
Can anyone advise to what hoses I will need, I assume the bottom will be fine as it'll be in the correct place, but if my research is correct I need a couple 90degree hoses and a section of metal pipework not too dissimilar from this:
And I'll be needing to make some custom mounts for it too...
Talk on the mini forum is people using Golf radiators as they enter/ exit same side, however this would put the header tank feed at the bottom, does this make a difference in how a header tank should work?
Thanks in advance for any advice, much appreciated!
