by Stuart » Thu Dec 04, 2008 2:01 pm
Here's a photo of a Gaz damper, I'm going to go for 9" long 120lb 2.25" dia springs with some 2" long 40lb run-flat springs, if you were to just use a 120lb spring the weight of the car would not compress the spring away from full extension at rest, this would result in an awful ride and 4x4 style ride height, using the run flat allows the suspension to drop about 1.75" at rest both improving the ride-height and also vastly improving ride comfort.
Some will say use a 95lb or less spring for a similar effect, I found them far too soft for my liking.
Hoefully Alan will be along to give his view about his mk3 convertible. On my mk3 I ran 160lb and a run-flat to good effect, hence the reason I wish to replicate the set-up on my mk2.
Hope that makes sense.
- IMG_0976.jpg (88.96 KiB) Viewed 13382 times
