Finally got some time on the Bronze this weekend to look at what remains of the interior which to be honest was not a lot.
This is the starting point:
The retrim is a bit of a budget job as funds are not exactly running over at the minute but it should look presentable with any luck. I've gone for MGF leather seats as MX5 ones seemed to be £50-75 more expensive. I picked up some carpet and Vinyl at Stoneleigh so the colour scheme is Lightstone Beige seats with grey piping and dark blue carpet.
I test fitted the seats today and did the basic fitting of the carpet. The tunnel in the centre of the car will require more work as the carpet just doesnt lay right due to the changes in height of the tunnel.
The seats feel a little high so a little more bracket removal on the runners may be required.
The next job is to trim the sides which will be painful as the carpet won't be edged around the quarterlights, the door openings aren't as bad because most modern car rubbers has an additional channel for the trim so I'll give that a bash. The door panels and dash shouldn't be so bad to do but I need some lightstone vinyl before I can have a go at that.
cheers,
Mike
