Rear dampers
Rear dampers
Postby Geoff Butcher » Sat Jun 21, 2014 3:58 pm
Apparently the Spax rear dampers are no longer available. Has anyone used Protech? Someone called 'Midas' on the Turbominis forum ordered some in a group buy a while ago. Or any alternatives?
Re: Rear dampers
Postby Rich » Mon Jun 23, 2014 11:02 pm
That would be me Geoff. They work well and are really nicely made, the specs I ordered are on here somewhere.
Re: Rear dampers
Postby Rich » Mon Jun 23, 2014 11:04 pm
Re: Rear dampers
Postby DavidL » Tue Jun 24, 2014 7:58 am
Brilliant, thanks. I'm needing to get a pair too, and I'd.decided on those - then put it off for some forgotten reason...
Re: Rear dampers
Postby Rich » Tue Jun 24, 2014 10:37 am
Well worth it, there's the usual problem with the top stem not being long enough for the glass body so you end up cutting bushes down.
Since fitting the rear undertray I would occasionally get a small grounding on full bump, if I was regularly running 2 up I'd be tempted to get slightly heavier springs, maybe 120-130s.
Re: Rear dampers
Postby Geoff Butcher » Tue Jun 24, 2014 8:00 pm
Thanks, Rich
Re: Rear dampers
Postby Rich » Tue Jun 24, 2014 11:34 pm
No problem Geoff, glad to be of help.
Re: Rear dampers
Postby Geoff Butcher » Tue Jul 22, 2014 3:58 pm
I'm a bit confused about this bottom mounting - do I gather that not all cars have the same? I have a bolt which presumably goes into a captive nut, but I haven't yet got the bolt out. A 5/8"/16mm socket won't go on and a 11/16"/17mm seems dangerously loose. Strange...
Re: Rear dampers
Postby DavidL » Tue Jul 22, 2014 4:20 pm
I think there are at least two different mounts, the original Midas one, and then possibly the GTM one? The ones I have are like a box section open along the top, the damper bottom eye sits in it and a bolt goes through into a captive nut. Perfect rust traps.
Mine wouldn't move either, I had to strip the brakes them remove the three through bolts from inside the drum, remove the damper top mount, then attack the remaining mass of rust (ie, bracket and bottom eye of damper) in the vice. No idea what the bolt head sizes were originally, but the socket or spanner that did the original tightening wouldn't have fitted - I resorted to hammering on a six point socket and using an airgun on them to get any movement at all.
Re: Rear dampers
Postby Stuart » Tue Jul 22, 2014 6:25 pm
Geoff Butcher wrote:I'm a bit confused about this bottom mounting - do I gather that not all cars have the same? I have a bolt which presumably goes into a captive nut, but I haven't yet got the bolt out. A 5/8"/16mm socket won't go on and a 11/16"/17mm seems dangerously loose. Strange...
a bit of corrosion then.
Return to Mk 3 Coupe
