Towing Points
Re: Towing Points
Postby Hans Efde » Mon Sep 01, 2014 5:09 pm
Peter Hills solution
Re: Towing Points
Postby stevew » Fri Sep 05, 2014 12:47 am
Interesting Hans, do you know how it is attached? Is it bolted to a load spreading plate straight onto the fibreglass chassis, or maybe a long piece of metal that goes back to the sub-frame?
stevew
Re: Towing Points
Postby Hans Efde » Fri Sep 05, 2014 7:51 am
stevew wrote:Interesting Hans, do you know how it is attached? Is it bolted to a load spreading plate straight onto the fibreglass chassis, or maybe a long piece of metal that goes back to the sub-frame?
Yes, I understood from Peter that is was a long piece of steel, bent and directly bolted to the subframe.
