My newly acquired Gold does not have a bonnet stay, and I would like to fit a gas strut.
I assume that this has been done before, if so, can anyone tell me which strut was used and where the mounting points would be?
Cheers
Dave
Hans Efde wrote:I have fitted 1 of the bonnet pins with a spring and glued the bonnet stay to the bonnet.
All diy stuff. Alu tube and the hinge is a roller wheel with the wheel removed. 2 tool clamps do the rest. If I want to work, I don't have to unbolt the bonnet stay prior to lifting the bonnet.
axshack wrote:My newly acquired Gold does not have a bonnet stay, and I would like to fit a gas strut.
Cheers
Dave
Geoff Butcher wrote:The bonnet is so light it hardly seems worth using a gas strut, also it would make removing the bonnet for access more difficult.
DavidL wrote:Hans Efde wrote:I have fitted 1 of the bonnet pins with a spring and glued the bonnet stay to the bonnet.
That's very neat, Hans. However, having had to work under the bonnet of my car in high winds before, I think I'll stick with my current sliding stay. Despite it rattling like crazy in gusty conditions, it has yet to collapse and thump me on the head. My worry is that those tool clips might distort and release their hold on the end of the rod if your bonnet happened to catch a high wind - have it been used in those conditions?
Hans Efde wrote:DavidL wrote:Hans Efde wrote:I have fitted 1 of the bonnet pins with a spring and glued the bonnet stay to the bonnet.
Yes, high winds will cause mayhem, but this applies to the boot and doors as well. I don't open it with high winds, or have someone hold it, or park the car with the nose in the wind. Even movement restricted parts will get damaged with high wind. Get a good wind in the bonnet or door and they will go beyond the maximum position and get damaged.
