bodyshell mk1
bodyshell mk1
Postby ilmung » Thu Apr 23, 2015 1:22 pm
Hi
I am looking for a bodyshell of a mk I midas ?
Geert
ilmung
Re: bodyshell mk1
Postby kelvink » Thu Apr 23, 2015 1:34 pm
Can you remember where you last had it? I'm sure that will help find it. ;)
Not so many Mk1's about but there's lots of Mk2s are you set on an Mk1 there's not a huge difference between them only really the wheel arches, front airdam and bumper
Re: bodyshell mk1
Postby ilmung » Fri Apr 24, 2015 6:09 am
The reason for the MKI is that's the only type of Midas where the frontsubframe is coming from a mini and not metro .
The mini spareparts are better to find and also cheaper in Belgium , I hope what I presume is correct ?
ilmung
Re: bodyshell mk1
Postby streetsy » Fri Apr 24, 2015 7:41 am
mk 2 also uses a mini front subframe.
Re: bodyshell mk1
Postby ilmung » Fri Apr 24, 2015 8:49 am
Hi
you are 100% sure ,
Geert
ilmung
Re: bodyshell mk1
Postby streetsy » Fri Apr 24, 2015 9:26 am
I had a mk2 (q319 nya in the photo or rebuild section of forum) it was a mini subframe in the front.
Re: bodyshell mk1
Postby Stuart » Fri Apr 24, 2015 9:48 am
MK 1
MK 2
Re: bodyshell mk1
Postby ilmung » Fri Apr 24, 2015 11:24 am
ok thanks for the reply , so I am looking for a MKI or MK2 with correct V5 where an engine of minimum 1275 cc is mentionned
ilmung
Re: bodyshell mk1
Postby kelvink » Fri Apr 24, 2015 1:04 pm
The Mk1 and Mk2 are based on exactly the same running gear it's just really the interior that's of any significant difference where the Mk2 does use a Metro instrument binnacle as opposed to the mini one. Otherwise it's all just cosmetic differences as I mentioned before. You'll find it a lot easier getting an Mk2.
Are you after an on the road pristine car, or a rebuild project, or something in-between?
Re: bodyshell mk1
Postby ilmung » Fri Apr 24, 2015 7:54 pm
If I would find a very very good bodyshell + subframes and without big faults and with a very fast engine .......it would be ok for me , but that will be very difficult I think ???
A 100% perfect race Midas with lot of power would also be perfect !
But only a good bodyshell without subframe and engine is also ok !
Important : The V5 should mentionned at least an engine of minimum 1275 cc .
I would consider every offer !
ilmung
Return to Wanted
