Headlight
Re: Headlight
Postby ilmung » Tue Jul 21, 2015 8:30 pm
Hi Stuart
Thanks for the info !
But as you said , they are expensive but seems complete and well done , in time of urgent need that may be a solution .
I have already considered to put a round headlight of 5.75 inch ( 146 mm) with the round mounting ring and springs (the MKIII has 7 inch) the mounting ring costs +- 19euro and the headlight +- 38euro together 57 euro ( 41 pound )for a complete headlight , of course you should adapt some things ...
Also the combined hella light 90 mm (dimmed & beam) cost +- 86 pound /piece and more easy to adapt , only 90 mm diameter.
ilmung
Re: Headlight
Postby ilmung » Wed Sep 02, 2015 8:05 pm
Hi
I found some headlights which fit very well in my Midas MKII .
ilmung
Re: Headlight
Postby ilmung » Wed Sep 02, 2015 8:08 pm
dimensions headlight : see attachement
Disponible :H4 + duplo version , setsrews with fixing parts ,rubber seal , but ........not the mountingframe but easy........ to make :)
cost for 1 lamp +- 50€ all in ( not mountingframe !!)
comes from fiat 126/127
BRN_DB2BF7_007749.pdf
(152.07 KiB) Downloaded 498 times
ilmung
Return to Mk 2
