Rear Beam Material
Rear Beam Material
Postby chase saddler » Mon Aug 03, 2015 9:02 pm
I am currently in the process of rebuilding my Midas Bronze. Can anyone advise what it was made from and if it was treated in anyway, i.e galvanised. The rust on it after 30 years is little more than surface rust. I intend to clean this off and re-treat but would be interested to know this information
chase saddler
Re: Rear Beam Material
Postby Rich » Mon Aug 03, 2015 9:35 pm
As far as I'm aware they were mild steel.
Postby chase saddler » Mon Aug 03, 2015 9:51 pm
Rich wrote:As far as I'm aware they were mild steel.
That was my thoughts. If that is the case it has withstood the test of time very well, which is why I wondered if it were galvanised.
chase saddler
Postby ACourtney » Tue Aug 04, 2015 6:54 pm
The original rear subframes were mild steel finished with yellow-passivated zinc plating. If kept clean, or covered with waxoyl (or other greasy film like stray engine oil) then the zinc plating will last reasonably well. If not and the frame is allowed to get covered in road grime, especially road salt during winter months, then the zinc plating will erode away.
A hot zinc galvanized coating is typically 20-50 times thicker than a zinc plated coating, but the steel needs to be fairly thick so as not to distort when dipped in the molten zinc.
Postby ilmung » Sat Sep 03, 2016 6:53 pm
Hi
Are the other parts of the rear....... mini or metro based ?
kind regards
Geert
ilmung
Postby Stuart » Sat Sep 03, 2016 7:23 pm
ilmung wrote:Hi
kind regards
Geert
Mini.
Postby Inim666 » Sat Sep 03, 2016 11:01 pm
That's odd as when I bought some rear wheel cylinders the mini ones didn't fit and had to use mk1 metro items
Inim666
Postby Stuart » Sun Sep 04, 2016 7:17 am
Inim666 wrote:That's odd as when I bought some rear wheel cylinders the mini ones didn't fit and had to use mk1 metro items
Metro backplates fit Mini radius arms, so that's a possibility.
Return to Mk 2
