Hi all,
just acquired an ed-Ford intertial switch to cut off the power to the Facet pump in the event of a front end collilsion
Got a question: should the switch be fitted so that the rolling ball inside is horizontal to the ground - or should I fit it with a slight upwards angle so that it operates at high G and NOT when braking heavily?
Cheeers
DAve
