by Jon » Sun Mar 27, 2016 12:18 pm
David - I have modified the glove box. Mine never had a cover, just a narrow perspex lip to stop things falling out. Having put the standard dash in and out of the car a couple of times I decided a removable glove box would make life a lot easier, so I cut out the GRP moulding and made up an aluminium version that inserts from the front. At the moment it only has the black frame; it might get a door one day if time and motivation permits. The removable glove box means that there is good access for connecting windscreen and fresh air vents, radio wiring etc. Makes life a whole lot easier.
Similarly, the modified Metro instrument pod now also goes in from the front. Also, the heater controls, fan switch and heated front screen switch are all on a panel fixed to the heater so none of that lot is affected by dash removal. I hate to think how much time has gone in to this, but I'm quite pleased with the overall effect.
