megasquirt/jolt
megasquirt/jolt
Postby max midas » Thu Sep 29, 2016 9:03 am
I'm getting all the bits assembled to install my megasquirt ignition.
Could anyone who has installed one of these advise on where they sourced the 25uF at goes between the coil pack and earth?
Or even if they've put one in at all as some builders online deem it unnecessary.
max midas
Re: megasquirt/jolt
Postby streetsy » Thu Sep 29, 2016 5:57 pm
I've got a mega jolt on my mk3 daily driver and used to have mega jolt on my mk2 daily driver, I have never fitted a capacitor on either car.
Re: megasquirt/jolt
Postby l_jonez » Thu Sep 29, 2016 6:55 pm
I've got megajolt and megasquirt setups, never used a capacitor
l_jonez
Re: megasquirt/jolt
Postby Geoff Butcher » Thu Sep 29, 2016 8:25 pm
Nor me. What's it supposed to do?
Re: megasquirt/jolt
Postby max midas » Thu Sep 29, 2016 9:09 pm
negate any rf interferance? I don't know, but the diagram I've been working from has one.
Do I have the right diagram?
max midas
Re: megasquirt/jolt
Postby streetsy » Thu Sep 29, 2016 9:16 pm
I thought that grounding the shield on the cable was to isolate from interference.
Re: megasquirt/jolt
Postby max midas » Thu Sep 29, 2016 9:29 pm
The sheild on the pip/saw cable and vr sensor isolate from false signals going to and from the main board, so I presume the capacitor is to stop rf noise on other stuff like radios.
max midas
Re: megasquirt/jolt
Postby max midas » Thu May 24, 2018 8:24 am
Right, I'm making my usual bi-annual attempt at installing megasquirt to control the sparks.
I've got it all loosely wired up, what do I have to download to make it work.
As you can tell, I'm more plug and play than geek, so I hope it's simple.
I'll take it to my local RR when installed and working to fine tune.
Many thanks in advance.
max midas
