I had an issue. When putting some stuff on the bench the other evening, I happened to knock one of the light lenses off, which hit the floor and broke. I have managed to find another on eBay (the correct side too - I did check!). I have glued the old one, but if it doesn't take I will still have the new one to help. Still, it's a pain in the **** that I could have done without.
As I am still concentrating on the rear end, I needed to sort the handbrake itself. The one in the car was of unknown origin, but was also knackered, with its button and internals either missing, seized or broken. So I got myself a standard Mini handbrake. This of course did not fit at all due to the Midas tunnel having no appropriate bracketry to mount it too. The Midas handbrake had horizontal mounts, whereas the Mini item's were vertical. Not helpful. Still, I am nothing if not resourceful. I had knocked up a bracket & spacer arrangement a couple of years ago but needed a half decent spacer to replace the hacked about steering drop bracket I'd used as a temporary measure. Once again Tink's spacer box helped, offering a perfectly sized item. I shall drill the holes in due course and mount it.
Moving on, I FINALLY found the bits I had been searching for: seatbelt stalk mount captive nut plates. I had put these in the cooling system parts box so I wouldn't lose them. It took the best part of 5 hours' searching to eventually unearth them. Luckily they'd already been reconditioned and painted. As I was on my own in the garage and don't have arms like Mr Tickle, actually getting them in place provided a slight issue. This was solved by popping the bolt through the bodywork, securing it with a ratchet & socket, then spinning the plate on until the rivet hole lined up. I then chucked a screwdriver through the hole and tightened up the bolt. This kept the rivet hole lined up nicely. I then simply removed the screwdriver and used a 16mm headed rivet to secure the plate. I also drilled a couple of extra holes in the plates to double up on the rivets. I still need to drill the new holes. Still , the first one is mounted with (the original arrangement of) one rivet. I ran out of time to do both (Took Mrs B out for her first drive of my daily) so will sort the other one next time.
Not the sort of thing you want to happen. I swore. Loudly.
Handbrake with better looking spacer (awaiting paint).
Been looking for these for AGES!
