- IMG_2471.JPG (106.5 KiB) Viewed 23342 times
- IMG_2469.JPG (131.8 KiB) Viewed 23342 times
The attachment IMG_2467.JPG is no longer available
After the holydays I enjoy again to continue the conversion .
I had some problems with the custom subframe to get the right geometry .
So I bought another standard subframe and made a new caliber again to be 100% sure so that I could regulate afterwards caster/camber as perfect as possible .
After some days working ,the custom subframe geometry was as the standard subframe .
Also I found out that the fast road lower arm bush is a little tricky
https://www.minispares.com/product/Clas ... 0to%20shopReason for that is when the bushes are not right installed the position of lower arm change a lot ( can go to the front or to the rear of the car !!!!!
Now once again I build in the engine /suspension/brakes/etc..... to find out another bad things
