Q316 GRN - Live
Re: Q316 GRN - Live
Postby manifold » Sun Mar 23, 2025 10:52 pm
Time for a tidy up. Can actually see the convertible again now. :D
Re: Q316 GRN - Live
Postby manifold » Fri Mar 28, 2025 12:58 pm
Backspace seems ok on these minilight wheels I bought.
5.5" x 13" backspace 107.8mm 4 inch pcd sitting on 175x50x13 tyres
Re: Q316 GRN - Live
Postby Stuart » Fri Mar 28, 2025 6:03 pm
Looks good (thumbs up)
Re: Q316 GRN - Live
Postby manifold » Fri Mar 28, 2025 6:46 pm
definitely need a thumbs up option on here like FB. Think this is available on later versions of phpBB. When I get chance I will download a local backup and see if I can integrate a later version.
Re: Q316 GRN - Live
Postby manifold » Mon Mar 31, 2025 4:03 pm
seeing as I am going to be under the car a bit I've decided to get a scissor lift. One for Rich :).....
Re: Q316 GRN - Live
Postby manifold » Mon Apr 07, 2025 2:05 pm
Looked on the floor and it looks like my Midas has an oil based nose bleed from being too high.. courtesy of the usual gearbox oil seal. :)
Re: Q316 GRN - Live
Postby Rich » Mon Apr 07, 2025 5:32 pm
It's weird seeing it all back to front....
I've toyed with the idea of getting one of those for a while, this week I finally got my Gold into a dry-ish environment.
Re: Q316 GRN - Live
Postby manifold » Mon Apr 07, 2025 9:07 pm
Rich wrote:It's weird seeing it all back to front....
Yes I knnow what you mean.
I've been mulling over the idea for a while myself Rich and just thought just do it. It does take the mickey out of getting under the car for sure. I have it wired into my 16A commando circuit.
Waiting on sorting out the back subframe set up once I get hold of some stub axles for the arms from Alan. This should make the job light work.
Simultaneously drilling out the 1/2" UNF rod ends for the Ti trailing arm setup, re-threading and moving up to some HQ 5/8" UNF rod ends as a back up plan. Looking at getting a new odyssey battery. the last one is now shot. Surprisingly the pit battery I have is still going strong after 15 years. Trying to source some rear subframes is proving to be interesting.
Re: Q316 GRN - Live
Postby Stuart » Tue Apr 08, 2025 8:37 am
The lift looks very useful David. (thumbs up)
Re: Q316 GRN - Live
Postby manifold » Tue Apr 08, 2025 1:53 pm
Thanks Stuart. Just need a couple of 7" x 2" long planks (or probably scaffolding boards) to jack it up a touch to avoid the exhaust grounding on anything (just in case). :)
Return to Mk 3 Convertible
