Another comparison for today.
I bought a few radius arm repair kits recently. This topic may have already been covered. Sorry if it has. I noticed that the radius arm repair kits for metros are getting rather a bit rarer now on ebay. So bear that in mind if you have a Mk3 or Mk4 Midas.
For interest I bought a mini radius arm repair kit to see what the similarities are. I did this knowing full well that the inner bush on a mini is scintered/ phosphor bronze which has to be reamed - but what I was interested in knowing is what the radius arm dust seals are like and what the outer needle roller bearings are like in comparison to metro ones.
It turns out that the mini needle roller bearings are exactly the same, along with the earlier (see above reference to the dust seals) are the same too. What is different though is the overall length of the radius arm shaft. Its a longer shaft on the mini (which I kind of knew anyway).
The nuts and threads are different too. Useful to know if your radius arm shaft is still in good working order but the needle roller bearings are worn out and your needing to get it back on the road, go for an MOT (if it still applies) or for whatever other reason.
I recon you can use the mini grease tube on the metro shaft too. Its actually longer... which is better at getting the grease to the opposite end which is one of the bug bears of this design. Especially on radius arms which are hollow.....which would need filling up with a lot of grease (a trick mini owners do).
