Brake master cylinder
Postby Geoff Butcher » Fri Mar 05, 2010 5:40 pm
I thought I'd rebuild my old cylinder but I can't get a kit locally. Looking at Ebay, SP7698 appears to be correct, can anyone confirm?
Re: Brake master cylinder
Postby Hans Efde » Sat Mar 06, 2010 10:32 am
Depends which type you have. There are 2. AP Lockheed or Lucas. These are different, so a Lucas kit won't be any good for refurbishment of an AP Lockheed master cylinder.
Have you found the cause of the leakage?
Postby Geoff Butcher » Sat Mar 06, 2010 12:40 pm
No, this query is separate from the leakage problem. My Haynes manual implies that there is only one m/c for a post-85 car with servo.
Postby nimdy » Sat Mar 06, 2010 4:05 pm
Geoff,
Which master cylinder is it? I have a brand new Lockheed one that I could be persuaded to part with if that would be easier.
Russ
nimdy
Postby Geoff Butcher » Sat Mar 06, 2010 5:36 pm
This is it
I changed it some time ago but the problem turned out to be the servo. Since this is in good condition I thought I'd treat it to some new seals and keep it as a spare
Postby Hans Efde » Sat Mar 06, 2010 8:37 pm
I suppose then that yours is a Lucas. Mine is an AP Lockheed and looks like this:
master cylinder.jpg (38.65 KiB) Viewed 6078 times
Postby Geoff Butcher » Sat Mar 06, 2010 9:14 pm
Hans, is yours 13/16" bore (20.6mm)? If so, I reckon the seals are the same
Postby Hans Efde » Sat Mar 06, 2010 9:55 pm
No the seals are not the same. I bought a seal kit from Ebay that didn't fit, it was useless. The differences are minute though. I have to find it in the garage to see what's on the box if you're interested.
Postby Geoff Butcher » Sun Mar 07, 2010 9:03 pm
Yes please, Hans - no hurry though!
