At least 2 different floor pans for the Mk 3 Coupe
Re: At least 2 different floor pans for the Mk 3 Coupe
Postby Victorc » Fri Feb 11, 2011 3:11 am
David,
My convertible has a very rusty rear subframe. (The front one gets protected by leaky engine). Can you hold on to the subframe you have, it may be a while until I can make the trip down to you?
Victor (Glasgow)
Victorc
Postby manifold » Fri Feb 11, 2011 12:58 pm
No probs Victor. I can hold it for a month or two. It will be outside under a cover round back of house.
Just note though this subframe is to suit a coil over system as the towers have been cut down. So no hydrogas.
Postby Victorc » Wed Feb 16, 2011 11:53 pm
Thanks David,
It should be ideal, as mine has the coil over system.
Victor
Victorc
