Front springs on a Gold
Re: Front springs on a Gold
Postby Rich » Fri Apr 15, 2011 12:04 pm
Hoping to have a pic of it back on it's wheels today. Just from jacking it up the spring side seems to have a height of 13", it will be interesting to see how it pans out when it's back on four wheels. Even if it stays at 13" I expect it will settle, plus of course my sylph-like weight might have a bearing too......
Postby manifold » Fri Apr 15, 2011 12:33 pm
Sounds about right.
When I needed to 'tweak' the adjustment of the ride height on mine I just jacked the wheel up to take the pressure off, then got the spanner in. Dropped the jack and checked again. Pressed the wing down (bounced it) a few times and checked again.
Didn't seem to settle much to be honest....maybe a few mm.
I'm really happy with what I have, but I can see the sense in doing what Alan is doing too, albeit it is more involved.
I havent had any of the noted issues with punching the wing in.
Postby Rich » Fri Apr 15, 2011 1:45 pm
It's already got dampers, I can't see why using springs instead of hydrolastic which both have similar levels of movement should be any different. I've got a decent set of poly bump stops in place which will stop the dampers bottoming out no matter what happens.
Postby manifold » Fri Apr 15, 2011 4:47 pm
I think you'll find its a better driving experience on the springs ;)....
Postby Rich » Fri Apr 15, 2011 7:01 pm
manifold wrote:I think you'll find its a better driving experience on the springs ;)....
Oh yeah.......... :D What a difference! It's still firm but just without that harsh edge, it all feels a little more controlled instead of zig zagging over every bump.
Postby manifold » Fri Apr 15, 2011 8:00 pm
have you driven it on the road today then? sounds like it ;)
you wont be disappointed.
Postby Rich » Fri Apr 15, 2011 9:12 pm
Yes it looked a little high and knock-kneed at first but it has settled to a height that looks 'right', I'm impressed with the difference in feeling.
I've fixed the fan and all the other bits but I've still go a miss-fire when the engine is hot.
Postby manifold » Fri Apr 15, 2011 9:17 pm
Brilliant.
Glad someone else has joined the dark side lol. ;)
......Just want to see some of these pics you promised ;)
Missfire could be plugs/leads when hot.
Postby Rich » Fri Apr 15, 2011 9:21 pm
manifold wrote:Brilliant.
I don't think I'll be going back to hydrolastic. I suspect my miss-fire is going to require an electric fuel pump to sort it.
Postby manifold » Fri Apr 15, 2011 9:24 pm
I think the harshness disappears as the springs are more balanced to the back end.
Harshness reduction was one of the surprising benefits though.....and it gives a generally more sure footed feeling on the road.
All I know is its a lot better than it used to be.
