Well I've managed to get out into the garage for an evening; my first job was to strip the spare engine that came with the Midas. It is believed to be an 1100 (no engine number), which apparently smoked and might have needed a rebuild. The main thing is, this engine is in the way and needs to be gone. My friend Shaun wants the gearbox casing, so I will cannibalise the engine for what I want (Non-verto clutch & flywheel bits), Shaun gets the whole gearbox and the rest will go up on Ebay at 99p start (buyer collects!).
I began by draining the oil. My mate Matt and I manhandled the lump onto some handy concrete blocks I have (easy as we're both built like rugby prop-forwards
) and after some persuasion with a 3ft bar and socket the sump plug was removed. What came out was not pretty and was darker and thicker than a molasses vat at night.
My guess is it didn't taste as good.
Time to remove the flywheel. Off came the cover and it was clear that this would have been undriveable as the oil seal had failed big time - so much oil spray in the cover and also on the pressure plate and backplate. Amazingly the flywheel gave up without too much of a fight - there was an extremely satisfying "crack!" - and then I set about removing the flywheel housing. There was of course, a bolt which wouldn't move and naturally it had a chewed head thanks to my pitiful attempts to remove it. So I got angry
produced my hammer and a 12mm socket and had it off and in the bin within seconds.
Just now got 6 bolts to remove the box and I will split them.
Cover off...
Clutch pressure plate...
... and ugly clutch (note awesome use of a shelf bracket as a flywheel-locking tool. I used to use a table knife but couldn't find it...)
Almost ready to split
Would have done it all but have a wedding to go to tomorrow so need to be ready for that!!
