Server downtime
Server downtime
Postby manifold » Mon Sep 12, 2011 7:11 pm
Dear all.
I am going on a 'trip' for a couple of weeks. Server will be running in my absence, but if it should fail, I won't be able to sort it out until I return. Hopefully it won't be shut down. It hasn't been off for the last month or so (since the hack).
Rich, If you could do a weekly back up of the forum (more would be even better), taking the sql file back up to your PC that would be great. Its under maintenance. Make sure you 'select all' files.
Re: Server downtime
Postby Rich » Mon Sep 12, 2011 8:36 pm
manifold wrote:Dear all.
No worries, I do an occasional download as well as the regular local back ups.
Re: Server downtime
Postby manifold » Mon Sep 12, 2011 11:13 pm
Cheers Matey.
I hope you get them there shock brackets sorted. I would have thought you would be turning some up on the lathe! ;).
Re: Server downtime
Postby manifold » Sat Nov 05, 2011 10:43 am
Just had a little impromptu downtime last night due to an unexpected power cut.
All up again now.
Return to General Chat
Users browsing this forum: No registered users and 12 guests
