Leaking doors
Leaking doors
Postby Stairheedrammy » Sun Sep 18, 2011 8:36 pm
Now that my rear swimming pool has been drained I notice that there is a gap between the doors and the rubber door seals, soaking the drivers seat- can I adjust the door or do I need to get a wider seal?
thanks
Mark
Stairheedrammy
Re: Leaking doors
Postby Hans Efde » Sun Sep 18, 2011 9:16 pm
The window frame should touch the seal. If the doors are correctly adjusted and the frame is in good condition (they can break just above the door, I glued a block of wood inside the door between the frame and the door to stabilize it). Also I glued a T-seal on top of the frame.It falls over the O-seal and seals the gap between the door and the monocoque. It looks a bit like this:
http://home.wanadoo.nl/hansefde/assets/ ... e_fig2.gif
Also make sure that rain that gets inside the door can drain. Usually rain runs via the inner side of the doorcard on the O-seal and back into the car. I used a piece of plastic to prevent it. It looks like this:
http://home.wanadoo.nl/hansefde/assets/ ... 9b86e0.gif
When you have done both things, your doors will be 100% watertight.
Re: Leaking doors
Postby lankyjames » Sun Sep 18, 2011 9:16 pm
Stairheedrammy wrote:Now that my rear swimming pool has been drained I notice that there is a gap between the doors and the rubber door seals, soaking the drivers seat- can I adjust the door or do I need to get a wider seal?
thanks
Mark
I get this, sometimes it seals just-about, but most of the time this can't hold water back...and it gets even worse when i wind the window down...
I have spare doors, but have not had the time to test if they fit any better and i am unsure of the amount of play or adjustment in the hinges!
Hans has a good article about seals and getting wet on his website - he'll be along soon enough :)
Edit; hans beat me to the punch already.
lankyjames
Re: Leaking doors
Postby Hans Efde » Mon Sep 19, 2011 11:19 am
lankyjames wrote:Edit; hans beat me to the punch already.
Yes I am connected to the forum like a Borg to its Hyve.
Re: Leaking doors
Postby Stairheedrammy » Mon Sep 19, 2011 6:28 pm
Thanks for this gents- Hans- where did you get the t seal, as I can seem to find any
thanks
Mark
Stairheedrammy
Re: Leaking doors
Postby Hans Efde » Mon Sep 19, 2011 8:12 pm
Stairheedrammy wrote:Thanks for this gents- Hans- where did you get the t seal, as I can seem to find any
thanks
Mark
I got it from this company: http://www.technirub.nl/
It is a standard extrusion rubber. I suppose a similar company in england should exist. Maybe these guys: http://www.phoenixtrims.co.uk/
Re: Leaking doors
Postby Stairheedrammy » Mon Sep 19, 2011 8:36 pm
Thanks Hans
Stairheedrammy
Re: Leaking doors
Postby johnnyfixit » Mon Sep 19, 2011 10:47 pm
just checked the new addition and mine has snapped on the passenger side also the door mechanism only lets the window go down half way more future developements
johnnyfixit
Return to Mk 2
