Front shocks
Front shocks
Postby PerS » Thu Oct 18, 2012 4:28 pm
Hi All,
I´m in the search for new shock absorbers for the front.
With no success I´ve tried to order at various establishments here in Sweden, but with no result.
Would it be possible to fit shocks for MGF´s?
I guess the one´s for MG TF with coilovers is overdoing it.
Per
PerS
Re: Front shocks
Postby Hans Efde » Thu Oct 18, 2012 4:39 pm
I bought the original Spax dampers. Went to the Spax website, found the s/n for Midas dampers, and checked several webshops that are linked to the Spax site. I forgot where I bought them, but can find the invoice if you want. Paid via Paypal and one week later got my dampers.
Not sure if the MGF ones fit.
Re: Front shocks
Postby Rich » Fri Oct 19, 2012 11:39 am
I had mine made up by Protech, the dimensions are in the Convertible tech section under Rear Coilover Dimensions. For some bizarre reason I can't link to the post for convenience as every post has the same URL for me.
Re: Front shocks
Postby manifold » Fri Oct 19, 2012 2:40 pm
...its because I am using URL masking to cover Dynamic DNS Rich.
Here you go:
http://midascarsforum.com/forum/viewtopic.php?f=55&t=1629&hilit=protech
Fronts: 13" open length, M27 upper mount and bottom mount is 3/8th hole diameter.
Rears: 400 series. 14.5" open length, 2 1/4" spring seats, M27 upper mount, Bottom mount is 32mm bonded bush with 12mm hole diameter.
Re: Front shocks
Postby Rich » Fri Oct 19, 2012 7:56 pm
I knew there would be some witchcraft David.
Just as a note, the standard rear coilovers don't use a 12mm bolt, neither do mine any more...
Re: Front shocks
Postby PerS » Fri Oct 19, 2012 8:14 pm
Thanks Hans and Rich,
The Protechs look really nice.
I´m trying to run the Midas as a daily driver and I´m hoping to take advantage of other models as the Classic Mini or for that matter the MGF, for parts. The Metro was not sold new in Sweden so parts are not available as in other Countries.
If the bottom mount of the front shock has a 3/8th of an inch in diameter this info is really important for me, thanks.
Any other info is surely welcome!
Per
PerS
Re: Front shocks
Postby Hans Efde » Fri Oct 19, 2012 8:26 pm
Per,
I paid 174,53 euro for 2 spax dampers and shipment to the Netherlands. I bought them at Silverstone Tuning ltd, p/n for the Metro Challenge F damper is G716.
Re: Front shocks
Postby PerS » Fri Oct 19, 2012 8:33 pm
Hans,
That is not too bad.
And they were adjustable as well?
Per
PerS
Re: Front shocks
Postby Hans Efde » Fri Oct 19, 2012 8:40 pm
yes:
This one has more settings than the original spax damper, so I have to find out what's the best. Usually these knobs corrode solid within a year.
Re: Front shocks
Postby PerS » Fri Oct 19, 2012 8:45 pm
Hans,
Nice photo!
I guess you can spray the knop and surroundings with a wax, as you do on yachts, to keep them from rusting.
Per
PerS
