One of the projects on my Convertible is getting a proper soft top on the car. I am not sure where and when this ends, so it may become a long thread. We'll see.
This morning I called a convertible specialist who advertises with custom made hoods. Sounds good, but it turns out it's just a fabric replacement of soft tops on rare cars (anything not produced in large numbers like the MG F or MX5 top). They don't design a folding frame. A custom made soft top is between 1500 and 2000 euro, so too expensive for me.
I looked at modifying the existing frame so it can fold. It is possible to get a "knee" joint in the main hoop, but when folded it will hit the roll over bar. I also tried to fold the standard PVC softtop I have and it didn't like that. Apparently the fabric of a folding soft top is specifically designed to be able to fold. Perhaps it's possible to change the frame so that it will get around the roll over bar when folded, but it needs a specifically designed soft top that will be very expensive. Builders of boat hoods do design the frames, but it's similar to what I have and the fabric is no more than tent like. It doesn't need to insulate against sound and wind speeds of over 100mph on boats. And still at least a 1000 euro for such a top.
An other option is to find a easy available soft top with frame. It should be a close fit as possible on the Midas. I would then adjust the frame to the Midas for final fit and have an upholstery specialist adjust the soft top.
There are several on Ebay and these can be bought from 100 euros/pounds second hand to over 450 pounds new. Examples are the Ford Streetka, MG F, MX5. Perhaps old school soft tops from the MG Midget or MG B. Rarer but possible a good fit are tops from the Kei cars like the Suzuki Cappuccino or Honda Beat.
My first guess was the Ford Streetka. I measured one up at a local car dealer and it looks promising, but not yet perfect. It is 10cm wider than the Midas and the window rail is so rounded I would need to get new glass in the doors. The frame of it is hugely complicated by the way. Friday I'll check a MG F and I am still looking for an MX5 nearby. TBC.
