Front Dampers
Front Dampers
Postby streetsy » Mon May 12, 2014 7:33 pm
Having recently bought another midas, looking round it I have noticed it doesn't have any dampers fitted on the front at all, the holes are there in the top arms and the body but no dampers. Looking at metro dampers I can only find standard specification, does anybody know of any others that may fit ie. rear mini dampers. As I have no damper I cannot measure up to compare myself.
Re: Front Dampers
Postby mikeeskriett » Mon May 12, 2014 8:36 pm
It depends on the spec of car the frame came out of generally speaking if it was a post '84 car the only models fitted with dampers were Turbo, Advantage and Gta the rest had dampers built into the Hydragas displacers.
Off the top of my head standard fitment for Midas's using the non damped displacers was Metro Challenge front shocks...
Part Numbers
MG Turbo/Gta/Advantage - ADU3076EVA
Metro Challenge Front Shock - Spax PSX - G716
Mike
mikeeskriett
Re: Front Dampers
Postby DavidL » Mon May 12, 2014 8:49 pm
I knew some Metros didn't use separate front dampers, but I had thought that all Hydragas displacers had built-in damping, and that shock absorbers were optional for extra damping.
How can you tell a damped displacer from a non-damped one?
Re: Front Dampers
Postby streetsy » Mon May 12, 2014 9:23 pm
The top arms have holes (with bolts and spacers in place) which leads me to believe that dampers should have been in place. The ride however is not really wobbly, not as firm as my mk2 was, but not overly loose. The donor was a 1981 Metro van den plas. If there is a way to tell apart the displaces it would be useful to know so as not to over dampen the ride and end up with incredibly hard suspension.
Re: Front Dampers
Postby Hans Efde » Mon May 12, 2014 9:42 pm
The high performance versions of the Metro (Mg, Turbo) had extra dampers. When the Gold came out, Spax had developed special dampers for Midas. They can still be ordered. I bought them a few years ago for my Convertible.
Re: Front Dampers
Postby mikeeskriett » Mon May 12, 2014 11:43 pm
Non turbo fronts are NAM4763 Turbo is possibly NAM4283?
mike
mikeeskriett
Re: Front Dampers
Postby Geoff Butcher » Tue May 13, 2014 8:21 pm
I've had Halfords' bog-ordinary Metro dampers on mine for years and they seem perfectly OK
Re: Front Dampers
Postby Stuart » Tue May 13, 2014 9:58 pm
Mini rear dampers fit, not sure how they compare length wise, I have a feeling they're exactly the same, but not certain.
Re: Front Dampers
Postby wolfie » Tue May 13, 2014 10:41 pm
Re: Front Dampers
Postby Hans Efde » Tue May 13, 2014 11:06 pm
I would like to mention that the correct damper length is extremely important. It should never bottom out, during the in or out stroke. If it does, it will destroy the handling of the car and cause damage to the monocoque. If you are going to experiment, make sure the suspension can travel to the up and down stop without the damper interfering.
Return to Mk 3 Convertible
