door hinge thread
door hinge thread
Postby Jin » Sun Dec 28, 2014 10:41 am
Hey up guys
Hope your all having a good christmas break?
I've decided to spend some time with a loved
one,
The midas
Wishing id spent it in the house watching rubbish on the telly cos its beconing a bit of a mare.
Silly me for thinking adjusting the hinges and inner frame would take a few hours. I started christmas eve...
Anyway what size is thr hinge thread welded to the hinge that passes through the shell?
I've probably worn the threads out due to having to remove the doors 20 odd times ( no kidding)
Cheers folks
Re: door hinge thread
Postby manifold » Sun Dec 28, 2014 6:26 pm
Either m8 or 5/16 unf. Why not grind the welds off and fit new bolts?
Postby Jin » Sun Dec 28, 2014 8:41 pm
Cheers mate the bolts are actually ok and I really don't want any extra jobs is there a chance they could be metric fine? I've tried m8 and unf without sucsess and I've lost one of the originals.
Any ideas?
Postby manifold » Sun Dec 28, 2014 10:22 pm
I can't see them being anything else....unless someone has retapped them to whitworth.
Postby Rich » Mon Dec 29, 2014 12:06 am
I've got one here, and a metric thread gauge. The threads don't appear to be metric which is a bit of a pain. I'll be replacing them with metrics in that case.
Postby Jin » Mon Dec 29, 2014 10:38 am
Cheers chaps. I'll double check unf later
Postby ACourtney » Wed Dec 31, 2014 5:29 pm
The originals should be 5/16" UNF. So if you have something different (BSF, or whatever) it will be because somebody has already ground off the original screws and replaced them.
I don't know why the design hasn't ever been updated to Metric. I'm still slowly working my way through the stock I inherited in 2004 and they are UNF.
Maybe sometime in the future I'll need to buy some more and then get them made in Metric.
Alistair
Postby Jin » Wed Dec 31, 2014 8:14 pm
Nice one cheers ill take another look tomorow , perhaps they are damaged and I need a die nut.
Postby Jin » Mon Jan 05, 2015 3:15 pm
absolutley right, they are 5/16 UNF
does beg the question what i was trying to wedge on the end?
cheers for your help chaps
