While taking my time to do the front foot wells I jumped on the chance to sort the parcel shelf, its current state was terrible
So without a moment to loose I whipped off the rusty boot hinges and blasted them
Quick coat of paint
With the boot lid removed now seemed like a good time to trim down the rear return edge of the boot lid since it caught the rear bulkhead below the screen each time it was opened and that’s with the boot lid set out of line in an attempt by the builder presumably to avoid the issue, in total around 10mm was trimmed off
Worth it though, now the boot lid could be realigned to perfection
Hinges reinstalled and a mod standoff made to cover them up after
Bought some black plastic project boxes from Maplin, quick trim down and hole drilled and all is good
Much nicer though I may carpet the hinge covers too
Onto the foot wells
The sound deadening was trimmed to fit snug
Carpet trimmed to fit in exactly butting up tight to the surrounding carpet, this way the joins are virtually invisible but the cutting has to be mm accurate, fortunately I managed it
Sound deadening shown for comparison
Dropped in and the fit is snug
Trouble is this is just going to slide around all over the place and I don’t intend to bond them to the floor since ill need to access the sub frame nuts etc. and need to mop up any leaks should they occur, so I bought some 10mm polycarbonate sheet which happened to be the exact thickness of the sound deadening
Cut it up to 2” circles
Got my money’s worth out of that
M6 stainless inserts
Bonded to the floor
With corresponding holes punched into the sound deadening
Perfect fit
Then step 2 was to bond the carpet to this
Then once set I whipped them out and sealed all-round the edges with polyurethane to make them one semi ridged removable waterproof floor section,
Then the last job was to punch out a 6mm hole that lined up with the threaded inserts in the floor locaters and some black flat alloy screws used to nip them down, no unwanted movement whatsoever and the screws will be hidden by some over mats
Work continues at the rear foot wells, the passenger side gave me a bit of a headache due to the fuel pump and main loom wiring running through this area, so I bonded some wood blokes to make a frame to support the carpet to the desired shape, I chose wood since ill need to access the wires from time to time so this section of the carpet can be secured with subtle black self-tappers
Also there needed to be access to the rear brake pipe clip screws from inside the rear foot wells, it seemed overkill to make the whole carpet removable and this carpet doesn’t sit flat too well either so it was bonded on with a lift up flap
Rear floor sections being made in the same way as the fronts, new bucket seats on order so things are progressing nicely…
