L_Jonez Mk2 rebuild
Re: L_Jonez Mk2 rebuild
Postby l_jonez » Sat Jan 23, 2016 9:10 pm
Well the exhaust flanges turned up today ( thanks miniswift)
So its ready for welding up
Turns out I'm my own worse enemy, I rubbed down some dodgy looking stone chip on the rear floor with the intention of fixing it
Then hours later I've decided that it all needs to come off :-(
l_jonez
Postby fozzza » Sun Jan 24, 2016 10:54 am
Its the usual way, with the best intensions a small job ends up being a major over hall. I'm having the same issue recommissioning my MK2, I started off with a set plan what I was going to do now my to do list is about twice as long. :roll:
At least you have got a good base to start with now rather than recoating over the old stuff and regretting it later.
Postby l_jonez » Sun Jan 24, 2016 8:00 pm
Manifold is not tacked together
Forgot that I need a flange for the turbo :(
l_jonez
Postby l_jonez » Wed Jan 27, 2016 7:38 pm
My father came over earlier, he had found the original brochure and a few articles he read which lead to him buying the Midas
Apparently there's a fair few photos of him building the car as well in the attic
l_jonez
Postby l_jonez » Sat Feb 06, 2016 7:17 pm
Really really need to decide on a colour for the respray now. My head is saying white but the Mrs suggested silver which I can't say I've seen on a Midas ? Or I've had a urge to paint one of the minis black tulip for years now but not sure if that would look right :-/
l_jonez
Postby Stuart » Sat Feb 06, 2016 8:37 pm
They look good in white, but there are a lot of white ones about.
ImageMidas Bronze (1988) by Steve Glover, on Flickr
Postby l_jonez » Sat Feb 06, 2016 10:55 pm
Hmmm silver is pretty good... Argh I hate choosing colours, it can make or brake a car
On a side note I cleaned all the oil/dirt/stone chip off the exhaust tunel and found a few sections that have been affected by heat
Going to repair the affected areas then treat the exhaust tunel to some form of heat sheild
l_jonez
Postby Stuart » Sat Feb 06, 2016 11:09 pm
I quite fancy this red, or is it just the car I fancy :?
Postby l_jonez » Sun Feb 21, 2016 7:39 pm
Forgot to post the small bit of progress last week
Did a bit more on the manifold, centres for runners 2&3 marked up, tack welds holding runners cut off and then attacked with a hole saw :)
Then the runners welded back on
Bit of porting to do where I had to much penetration *sniggers* then the flanges can get welded on :D
l_jonez
Postby Hans Efde » Tue Feb 23, 2016 7:38 pm
Great job on the manifold. Yes metallic red is a great color for a Midas. I am not aware of any Bronze,but there are a few Gold's. One in Sweden, one in Japan and one in the UK.
I've heard the Murray mid engined Bronze is alos metallic red, but I have never seen pics of it when it was finished.
