Mk2 R1 Promotive conversion
Postby Jvr19630 » Wed Apr 13, 2016 8:51 pm
Finally ran out of excuses not to start this conversion. I have been collecting parts for a while now and finally cleared enough space in the garage to get going.
Starting off by building up the complete front subframe/engine with suspension and brakes
I will post when i can but may be a bit hit and miss with time restaints.
Promotive kit number 66
R1 5JJ engine with modified cam timing, uprated clutch and baffle plate for oil surging
Jvr19630
Re: Mk2 R1 Promotive conversion
Postby Rich » Thu Apr 14, 2016 12:37 am
Looking forward to seeing how this one pans out, I'm predicting somewhat mental!
Postby kelvink » Thu Apr 14, 2016 9:54 am
This is going to be a rather exciting project :-)
Has it got a reverse facility?
Postby l_jonez » Thu Apr 14, 2016 10:33 am
Damn this is going to be epic
l_jonez
Postby Jvr19630 » Thu Apr 14, 2016 7:42 pm
Hi Kelvink,
The kit i have is the later one with an engine driven reverse gearbox so no electric motor for me
Jvr19630
Postby Jin » Sun Apr 17, 2016 8:23 am
This looks exciting :)
Postby Jvr19630 » Sun Apr 17, 2016 5:15 pm
Well, rather than building i was stripping the modified differential unit to have a look. on the forums it appears these units can leak so i thought sort now rather than later. I will clean all the sealer off and do a dry build to find any issues.
Also a picture of the reverse gearbox
Jvr19630
Postby manifold » Tue Apr 19, 2016 8:11 pm
loving it. keep the pics coming.
Postby Jvr19630 » Thu May 05, 2016 10:24 pm
Found the fault on the diff unit, the locating dowels where drilled in the incorrect place forcing the two halves to twist.
I have sorted this (after a lot of messing about) and everything now lines up correcty. Will reassemble at the weekend
Jvr19630
Postby Jvr19630 » Mon May 09, 2016 8:20 pm
Test fitted engine into the subframe
After a couple of strip downs and adjustments here it is
Jvr19630
Return to Engine conversions
