L_Jonez Mk2 rebuild
Re: L_Jonez Mk2 rebuild
Postby Stuart » Sat Sep 17, 2016 7:32 pm
Exposure to them certainly boosts the enthusiasm, I could do with a bit too, actually make that A LOT.
Have you got a photo from the front with the engine poking out?
Postby l_jonez » Sat Sep 17, 2016 9:15 pm
Don't seem to have a pic from the front which is weird as I remember taking some from various angles. Next time the engine is in I'll take a pic and post it up.
l_jonez
Postby kelvink » Sun Sep 18, 2016 9:49 am
Aha! I thought there were too many coincidences at Castle Combe yesterday! Now I can put a couple of faces to your posts here on the forum. Good to have met you yesterday and hearing more about the car. Looking forward to seeing you joining us at future events.
Postby l_jonez » Tue Sep 27, 2016 8:42 pm
Stuart wrote:Exposure to them certainly boosts the enthusiasm, I could do with a bit too, actually make that A LOT.
Here you go
l_jonez
Postby Stuart » Tue Sep 27, 2016 8:48 pm
Thank you, not so drastic then.
Postby l_jonez » Tue Sep 27, 2016 9:02 pm
Nope I'm pretty sure I'll be going for a more modern headlight unit but if I keep the original I'd have to space it out this much....
l_jonez
Postby Stuart » Tue Sep 27, 2016 10:05 pm
Lost in the space, but would look a bit daft on its own, it'd need fitting in something that looked similar to a larger light.
Hella Bi-Halogen 002.jpg (138.07 KiB) Viewed 50083 times
Postby l_jonez » Tue Sep 27, 2016 11:06 pm
Stuart wrote:Lost in the space, but would look a bit daft on its own, it'd need fitting in something that looked similar to a larger light.
90mm hella?
l_jonez
Postby Stuart » Wed Sep 28, 2016 9:03 am
Yes, probably not the brightest lights compared to a xenon version, they're quite long though, but you can of course position them further forward.
http://www.myhellalights.com/index.php/ ... mp-module/
Postby l_jonez » Wed Sep 28, 2016 9:42 pm
I was looking at the 70mm units that are separate dip and main which would mean a quad light set up, which could be interesting :?
l_jonez
Users browsing this forum: No registered users and 25 guests
