by Alan D. » Sun Mar 28, 2010 7:38 pm
It's a Mk 1 or 2 beam axle and not a Mk 3 beam axle!
Mk 1's or 2's were built to three different standards, Gold,Silver or Bronze. So you can have a Mini based car designated as a Gold aswell!
With regards to progressive springs, My opinion is that you should fit two differing springs on the same coilover, say a 60lb (2" long)short spring to take the initial load (also giving an initial softer spring set up, saving my old bones!) It also stops the bottoming out bang, when the spring goes onto full droop when the wheel falls into a pothole. Then the second spring is a longer(9"long), say 90 or 100lbs load, is there to take the normal loads. This idea works very well on my Mk 3. Stuart put me on this idea, the only thing that we cannot agree on is spring rates!
With regard to a Mk 3 rear beam, I'm working on that at the moment. I have two solutions rose joints and a tubular (CDS) radius arm or the standard radius arm with camber and toe adjustment! I'm also trying to do the same thing for the Mk1 & 2!
More news soon!
- Subframe Radius Arm Brackets4.jpg 2.jpg (62.55 KiB) Viewed 8265 times
