rear coilover brackets for midas gold
Postby manifold » Thu Mar 31, 2011 1:08 pm
No disrespect to those who like cross dressing but theres no way I am putting a skirt on my car. :shock:
Postby Rich » Fri Apr 01, 2011 9:16 pm
One of the guys over on Turbo Minis has a group buy on Protech dampers/coilovers going, might be worth a look........
Postby b1zbaz » Sun Apr 03, 2011 12:01 pm
how do you put photos on
b1zbaz
Postby manifold » Sun Apr 03, 2011 1:29 pm
Create an account in Photobucket (www.photobucket.com) and upload pictures there. There is a link function in photobucket which you can click which auto copies it for you. Then you click and paste in your message and your link should appear. It should start in "[url]" and end in "[/url]".
Postby b1zbaz » Tue Apr 05, 2011 10:58 am
the group buy on turbo minis will they be the same as mine or different
b1zbaz
Postby DavidL » Tue Apr 05, 2011 11:29 am
b1zbaz wrote:the group buy on turbo minis will they be the same as mine or different
If they include springs, and they're for fitting to a standard Mini, then the spring rate will probably be too high for a Midas.
(edit) That applies to the rears. Fronts, I think, would be about the same rating.
Someone more up-to-date care to comment?
Postby Rich » Tue Apr 05, 2011 7:45 pm
You pick the dampers/coil overs from the Protech site, the springs are extra so you use whatever you want.
Users browsing this forum: No registered users and 23 guests
