by moss » Thu Jun 16, 2011 10:49 am
you could get a pair from alternative cars (bumpers that is)
tony
moss
by Rich » Thu Jun 16, 2011 12:42 pm
The stem numbers denote the use of two or four washers in the top mount. I forget which way round it is.
by Stuart » Thu Jun 16, 2011 1:59 pm
Rich wrote:The stem numbers denote the use of two or four washers in the top mount. I forget which way round it is.
Is that metal washers either side of the rubber bushes, if so guessing the stem may be longer on the one with 4 washers and so perhaps more suited to the thick GRP on a Midas
by Rich » Thu Jun 16, 2011 3:14 pm
Stuart wrote:Rich wrote:The stem numbers denote the use of two or four washers in the top mount. I forget which way round it is.
Yep, that's it, though I don't think there was a difference in overall length,
by Stuart » Thu Jun 16, 2011 3:58 pm
Have you got a photo of your new dampers, that is if you have them now of course.
by roliroller » Thu Jun 16, 2011 5:21 pm
Thank you all very much for your helpfull posts.
I understand that the best length of the damper would be 13inch or 14inch. Sprigs should be used 2'' run-flat with 40lb in combination with a 9'' long spring with 100-120lb. I´m going for these in the next days and post a foto if I got them.
Nice greetings Roli
roliroller
Users browsing this forum: No registered users and 20 guests
