Last weekend I removed the engine. Today I removed the release bearing housing and diaphragm spring cover. I found that the spring was an orange one, so it seems there must be an assembly error that has cause the excessive play on my crankshaft. I also found that the thrust plate was discolored and had a damaged inner edge. The release bearing has about a 1.5mm radial play.
Here are a few pics of what I found:
I have a few questions i hope you can answer:
- may the release bearing have radial play?
- is this normal for the thrust plate to look like this?
- what kind of bolts goes into the flywheel for the puller, metric ones or imperial size? I tried M10 bolts but they did not fit. Or should I try M10 with UNF thread?
I am also looking at buying a flywheel puller. I've seen one made of a thick plate of steel, but also severalones with slots in them and thinned out. Like this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Are these any good or should I avoid them?
