Swift Gti Turbo RWD project.. parts collection atm
Re: Swift Gti Turbo RWD project.. parts collection atm
Postby Stuart » Thu Jan 05, 2012 9:17 pm
I hope you have narrow hips, are you sure you have room for that gearbox? or perhaps it won't go so far forward as to affect the seat area?
Postby miniswift » Fri Jan 06, 2012 8:11 pm
Hi Stu,
I checked that gearbox is 570mm from the diff centre front section of the gearbox.
I also checked my std Mini seating position and I have 760mm from the centre line of a rear wheel arch. I think wheel base of Midas is 4"(100mm) longer so I should be OK.
This Volvo 360 setup is very good as it uses a torque tube, it make more or less separate chassie. I think old Lotus has similar setup.
People are talking about make sure I have to have good spread of subframe mounts and so on. I would have front subframe which will use std subframe mount position as per design of Midas. I will have a torque tube which have prop shaft inside but it will connect an engine to a gearbox as 1 unit. I hope I make sense to you people!
Cheers
Atchi
miniswift
Postby Stuart » Fri Jan 06, 2012 8:46 pm
570mm leaves you with plenty of room. :)
Can you keep the standard steering rack and position then?
Postby miniswift » Fri Jan 06, 2012 11:13 pm
That's my friend is my main concern with this build.
I might use nova steering rack. I think they are type that arms are about 2-3" below main body.
miniswift
Postby Stuart » Fri Jan 13, 2012 7:31 pm
Here's mine on 175/60-13 tyres to give you an idea how your 185/55-14's may look
Postby miniswift » Fri Jan 13, 2012 8:24 pm
Hi Stu,
The back end looks high on yours.
Are all Midas like that?
I have bought Yamaha R1 rear shock for my build with double wish born setup.
They are adjustable height as standard so it might be OK. I worked out that I will need to cut 50mm off wish borns and 200mm off subframe itself.
Cheers
Atchi
miniswift
Postby Stuart » Fri Jan 13, 2012 8:51 pm
It was very high, that's standard factory Midas set-up, nearly all were like that. I got around to lowering it a short while after that.
Postby b1zbaz » Sun Jan 15, 2012 8:28 pm
good luck this promises to be an interesting thread your a clever bunch on this forum i love reading through the projects section
b1zbaz
Postby miniswift » Mon Jan 16, 2012 7:58 pm
Oh..thanks!
I just make it up as go along :lol: .
I think I'm getting my bell housing machined this week sometime.... I hope.
Then I will get my engine block will be bored to 75mm and skimmed.
I'm not sure if I want to fit oil squirter or not.
Cheers
Atchi
miniswift
Postby miniswift » Sat Feb 04, 2012 12:07 am
Hi,
I got my bell housings from the machine shop back!
This is Swift Gti half gearbox casing.
This is Volvo 360 bell housing machined down to what I need.
This is what I will end up. I know it's not pretty but as long as it works, I don't mind.
I will be sending these 2 bits to my mate so he can Tig weld it for me.
Cheers
Atchi
miniswift
Return to Engine conversions
