Undertrays
Re: Undertrays
Postby Hans Efde » Wed May 16, 2012 9:09 pm
These are the mk3 ones I bought a few years ago from Alistair:
You can see the standard holes where the engine and exhaust goes.
Re: Undertrays
Postby wolfie » Thu May 17, 2012 1:13 pm
Don't suppose anybody has got any spare? Got my convertible from GTM so no undertrays or inner arch thingys for the front
wolfie
Re: Undertrays
Postby max midas » Thu May 17, 2012 11:52 pm
I fitted my inner arch thingys many years ago, but took them off due to overheating.
Not too sure how much use they are.
max midas
Re: Undertrays
Postby manifold » Fri May 18, 2012 8:51 am
I agree about the overheating with the shark fin inner wings.
They may probably be fine with a standard 1275 cc engine, but as soon as you up rate the power (and as a consequence create more heat) you will get overheating issues without some form of cooling compensation elsewhere (e.g. ducting). It was certainly an issue for me. Basically you are boxing in all the heat in the small engine bay. Good for under trays aerodynamics....bad for engine.
This proof is born out by the fact that the later Mk3's had to have 2 extra chimney vents in their bonnets above the exhaust manifold to try and counter this problem....probably as a result of having the 1380cc (Avonbar?) engines as a factory option.
Re: Undertrays
Postby Hans Efde » Fri May 18, 2012 11:28 am
There are 2 solutions for this. First is to get air via hoses to the engine bay as I did with my turbo engine. I cut an extra hole in the bumper. This cured the overheating engine bay (but in a traffic jam it still caused problems). The second solution is to remove the rear edge of the bonnet. This creates a slot between the bonnet and the windscreen sucking out all heat. I found it on my first burgundy MK3 coupe which is now in Swedish hands. That car had the side panels, undertrays and an 1400cc Avonbar engine and never caused an overheating problem.
Re: Undertrays
Postby lankyjames » Fri May 18, 2012 11:46 am
Any photos of these side panels, never once heard of them!
On a side note; I am thinking of adding another section to the photo gallery, for misc photos of midas' related things, such as an 'undertrays' section, 'exhausts', 'wheels' things like this, any thoughts?
Re: Undertrays
Postby Rich » Fri May 18, 2012 1:41 pm
I've just picked up.a pair, I'll take a photo and post it on the thread.
Re: Undertrays
Postby Rich » Sat May 19, 2012 3:39 pm
Rich wrote:I've just picked up a pair, I'll take a photo and post it on the thread.
There we go!
Now here's a question, which side of the inner wing flange to these mount to? Inner or outer?
Re: Undertrays
Postby Stuart » Sat May 19, 2012 4:05 pm
Outer
Re: Undertrays
Postby Hans Efde » Sat May 19, 2012 4:06 pm
On both my coupees they were fitted on the outside, i.e. in the wheelarch.
Return to Mk 3 Convertible
