Front coil springs
Luckyun
Front coil springs
Post by Luckyun »
Hi All
I'm about to order a fornt scoil spring kit from Watsons Rally. Any advice?
Lucien
Re: Front coil springs
Post by Rich »
I can't advise, but I will be very interested in the results.
what do you want to know? :)
I have the black road springs in mine and they are absolutely spot on for me.
Luckyun
Post by Luckyun »
Anything you might do differently second time round?
Lucien
get an extra pair of hands when you crow bar the springs in :).
Grind a small shamfer to the outer edge of the locating ring and make sure you dont fit the bump stop rebound buffer until after you've fitted the spring assembly.
Plenty of grease/copper slip to help it in.
Other than that, no. I'm really happy with it.
The driver feel of the car is a quite different than on gas. Especially when you dont know how much fluid is actually in the hydrogas unit. If its all fluid and no gas, as the old chambers will probably be you will end up with rock hard suspension as the fluid has no where to go to in the top chamber.....one of the reasons you see cars having to be pumped up and no sign of the nuclear powered fluid leaking.
Luckyun
Post by Luckyun »
That is very helpful thankyou very much.
Lucien
Adding a collar to the top of the tower before welding the top plate on would help. The A-series tower is shorter than the K-series one, and the Watsons kit is designed for the K-series frame.
Luckyun
Post by Luckyun »
I was wondering about that, so that one has more adjustment in the hi-los
Thanks
Lucien
Luckyun
Post by Luckyun »
The springs are on their way!
Good luck fitting them!
Have you got a spare subframe to work on, or are you using the original Midas one?
Great thing is you can reverse the process and grind the top hat caps off. Doubt you will though once you've tried them.
Make sure you seam weld the top hat on on both sides...ie underneath as well as on top.
Kind regards,
D
Return to “Mk 3 Coupe”
