CV Joints
CV Joints
How on Gods green earth do you split the CV joints from the drive shafts?
The Haynes manual shows a 'special' tool but the explanation makes no sense to me at all.
Re: CV Joints
Post by manifold »
....i've got the special tool.
Its a wedge that goes between output covers and the Inner CV.
Minispares sells them and they are very good.
Re: CV Joints
Thanks, I'll have a look.
Re: CV Joints
Which joints? inner or outer?
Both are held in place by a circular circlip which will compress into its own groove. It's best to hold the shaft in a vice and then give the CV a sharp tap, tap the middle of the outer CV closest to the drive-shaft (I use a socket extension bar. something softer should really be used) and the metal tube bit on the outer one.
I think David misread your post :)
Re: CV Joints
I think David is thinking of the tool that pulls the driveshaft out of the diff housing. The official tool is a sort of wedge shaped fork. My drive shafts just pulled out by hand, although in the past I have used 2 large screwdrivers or tire lifters for the stubborn ones.
Re: CV Joints
Post by manifold »
ahhh yes you are right.
Sorry I was confused about that. Mine is black and wedged shaped. Great tool and doesnt damage the side covers like screwdrivers can. Been there done that.
Never seen a tool to disengage the splines off the CV except a BFH (big F**k Off Hammer) and a vice. But only in exceptional circumstances where CV has rusted on splines. Good reason to strip down the shaft every now and again!
D
Re: CV Joints
Excellent! BFO adjustable spanners I can do.
Return to “Mk 3 Convertible”
