Rustoleum
max midas
Re: Rustoleum
Post by max midas »
Well I was so impressed by the Rustoleum on the front bumper (still only one coat, not flatted or polished), that I thought it was time the hard top was painted.
Before picture, with UV damage to colour
I spent an evening flatting back the surface to produce this
The scratches look bad, but aren't deep
During the next 5 days I applied one coat per day, no sanding in between as I want a good thick coat to start with. It only took 15 minutes to apply each coat.
After picture, 5 coats, no sanding or polishing
Click below link to see video
http://s1273.photobucket.com/albums/y40 ... c3c095.mp4
Bear in mind this is the raw finish, no sanding/flatting and no polish.
It's back on the car now and I'll let the paint cure for a month or so before finishing it all off, but am pleased with it so far. Shame it's raining and you can't really see the lovely glossy finish.
b1zbaz
Re: Rustoleum
Post by b1zbaz »
I can't seem to see any of the pictures mate
max midas
Re: Rustoleum
Post by max midas »
Is that better?
Will get the hang of photobucket one day.
b1zbaz
Re: Rustoleum
Post by b1zbaz »
Yes that's the ticket it looks good mate
max midas
Re: Rustoleum
Post by max midas »
More coats on the front bumper, it's had 4 now with flatting back between the 1st and 2nd.
Like the hood, I'll let it 'cure' for a month or so before finishing it off.
The picture doesn't really do the gloss justice, but you can see how little the orange peel effect is.
MrBounce
Re: Rustoleum
Post by MrBounce »
Is it the standard CombiColor Gloss you used Max?
Like this? http://www.rawlinspaints.com/products/R ... z5Wrs.dpbs
And were the rollers foam?
max midas
Re: Rustoleum
Post by max midas »
Hi, yes standard colours, can't remember them just now (and am not going to get out of bed to look :-) ), I'll update on the Ral numbers tomorrow.
Standard cheap foam rollers from Wickes.
Been too busy to either paint more, or flat back and polish these last few months, but may be able to get a garage in the nearish future, can carry on till it gets really cold then.
