Revolution wheels for a Gold?
Not sure if these fit, so may be worth checking the offset prior to bidding.
http://www.ebay.co.uk/itm/Midas-Gold-13 ... 461578f809
Re: Revolution wheels for a Gold?
They'd stick out a bit on a mk 3 and also need the inner part of the centre bore enlarged, OK for the mk 2 of course if you like big heavy wheels.
Stuart wrote:They'd stick out a bit on a mk 3 and also need the inner part of the centre bore enlarged, OK for the mk 2 of course if you like big heavy wheels.
That could be a milling job in one go. Enlarge the bore and take a bit from the inner flange.
You can't take much off the centre though due to the position of the wheel nut fixings.
Return to “eBay links”
