Power steering
Power steering
Post by wolfie »
Has anybody ever considered power steering on their midas? The missus is a wimp so I've been looking at the column from an mgf with epas system. If nobody else has ever tried it I will and find out if it will work, the only issue I can see is clearance under the dash
Re: Power steering
Post by Alan D. »
The Mini people use a Vauxhall Corsa steering column, mated to a Mini steering rack and someone on EBay sells a variable controller, so you can adjust the amount of assistance. The assistance is normally adjusted by the ECU, relative to your speed. One of our local people has shortened an MGF/TF steering rack, which he is fitting in a Mk 1 Midas with a Honda D series engine. there are pictures on this forum.
Stuart, I've tried to find the "Sticky" on the 16V forum, but failed, maybe you can assist.
Re: Power steering
Alan D. wrote: Stuart, I've tried to find the "Sticky" on the 16V forum, but failed, maybe you can assist.
Not an easy find as you say http://www.16vminiclub.com/forums/showt ... hp?t=16507
Re: Power steering
Post by Alan D. »
Thanks Stuart,
That should answer most questions for "Wolfie"
Re: Power steering
Post by wolfie »
Thanks for that guys. The corsa system seems slightly more compact than the MGF one which will help
Return to “Mk 3 Convertible”
