I'm fairly sure I'll go the Watsons route in any case, but the thought of using Mini rubber cones has been rattling around in my head for some time. I think I've been convinced, partly by watching the Moke video. That was a real dilemma as I love Mokes (despite never having driven one) but I find Mike Brewer very hard work...
Another spring conversion
Re: Another spring conversion
Thank you everyone!
My uncle has a moke with minitastic springs, the softer option of the three grades available. It's is comfy, as comfortable as you could expect to be in a car without doors, but there is a lot of body roll (2cv levels of roll!). I'm hoping to go for standard springs (rather than hard or soft).
Today was quiet at work so I made my turrets, going to autojumble at Newark on Sunday to see if I can get some 7078 (I think) aluminium to make my own short HiLo's.
- Top Mounts.jpg (73.16 KiB) Viewed 7863 times
If you have a dig around for my thread on the subject you'll see I modified a set of standard Hi-Los by machining them to fit upside down.streetsy wrote:My uncle has a moke with minitastic springs, the softer option of the three grades available. It's is comfy, as comfortable as you could expect to be in a car without doors, but there is a lot of body roll (2cv levels of roll!). I'm hoping to go for standard springs (rather than hard or soft).
I have seen your thread, hence the hole in the top of the mount, if I can't get any aluminium at a good price I think I'll be modifying a set of hilos in the same way
I've got the watsons springs but haven't fitted them yet. I'll be running them alongside some fully adjustable dampers so I can play around to hopefully get the perfect(ish) ride
