Towing Points
Re: Towing Points
Peter Hills solution
stevew
Re: Towing Points
Post by stevew »
Interesting Hans, do you know how it is attached? Is it bolted to a load spreading plate straight onto the fibreglass chassis, or maybe a long piece of metal that goes back to the sub-frame?
Re: Towing Points
stevew wrote:Interesting Hans, do you know how it is attached? Is it bolted to a load spreading plate straight onto the fibreglass chassis, or maybe a long piece of metal that goes back to the sub-frame?
Yes, I understood from Peter that is was a long piece of steel, bent and directly bolted to the subframe.
Return to “Mk 3 Coupe”
